Ga door naar hoofdinhoud
Motorola Droid Bionic LCD Replacement
Wat je nodig hebt
  1. Motorola Droid Bionic LCD Replacement, LCD: stap 1, afbeelding 1 van 1
    • Remove the back battery cover.
  2. Motorola Droid Bionic LCD Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery
  3. Motorola Droid Bionic LCD Replacement: stap 3, afbeelding 1 van 2 Motorola Droid Bionic LCD Replacement: stap 3, afbeelding 2 van 2
    • Remove the 11 T4 Torx Screws
    • Next, remove the information sticker.
  4. Motorola Droid Bionic LCD Replacement: stap 4, afbeelding 1 van 2 Motorola Droid Bionic LCD Replacement: stap 4, afbeelding 2 van 2
    • Using a plastic removal tool, work around the edges of the back housing.
    • Lift off the back housing.
  5. Motorola Droid Bionic LCD Replacement: stap 5, afbeelding 1 van 3 Motorola Droid Bionic LCD Replacement: stap 5, afbeelding 2 van 3 Motorola Droid Bionic LCD Replacement: stap 5, afbeelding 3 van 3
    • Remove the two silver T4 screws securing the SIM tray.
    • Carefully lift the SIM tray to disconnect it from the board.
    • Carefully remove the plastic spacer beneath by lifting gently in the center with a plastic removal tool.
    • Then, using a plastic removal tool, disconnect the speaker & front facing camera assembly from the board. The speaker is attached with adhesive, so be careful not to rip the flex cable.
  6. Motorola Droid Bionic LCD Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the 2 digitizer connectors using a plastic removal tool.
    • Then disconnect the LCD connector
  7. Motorola Droid Bionic LCD Replacement: stap 7, afbeelding 1 van 2 Motorola Droid Bionic LCD Replacement: stap 7, afbeelding 2 van 2
    • The board is now free from all connections. Carefully lift from the top and remove the board.
  8. Motorola Droid Bionic LCD Replacement: stap 8, afbeelding 1 van 2 Motorola Droid Bionic LCD Replacement: stap 8, afbeelding 2 van 2
    • Carefully peel the two flex cables from the back housing of the LCD. Be exceptionally careful during this process, as those flex cables can be easily ripped.
    • With the flex cables out of the way, you can now use a plastic opening tool to carefully pry the old LCD loose and out of the display.
    • If you're installing a new LCD, simply add it now and follow these instructions in reverse to complete the installation.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Taylor
244 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 20
Altijd: 1,883
