Inleiding
In this guide we provided the necessary information to help you remove the motherboard on your Droid 4. This will help if your phone have a defective motherboard or if there is a need to replace any component attached to the motherboard.
You will need to remove several torx head screws. Make sure to use the correct type.
  1. Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens. Slide the cover down to remove. Slide the cover down to remove.
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Remove the sticker on the rear compartment to reveal the battery.
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
  3. Using the blue plastic opening tool, pry off the thin plastic camera cover. The plastic cover is fragile, so proceed carefully. The plastic cover is fragile, so proceed carefully.
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit. The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
  6. Insert the spudger between the rear bezel and the main housing. The bezel is fragile, so proceed carefully. Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
  7. Remove the 12 screws holding the housing in place using a T5 Torx screwdriver. Follow the red circles, indicated in the picture, to locate the screws.
    • Remove the 12 screws holding the housing in place using a T5 Torx screwdriver.
    • Follow the red circles, indicated in the picture, to locate the screws.
    • The 12 screws are (silver) philips 2.5mm
  8. Separate the housing from the motherboard. Be careful while separating the housing. The power and volume buttons are easily separated from the housing and can be damaged. Be careful while separating the housing. The power and volume buttons are easily separated from the housing and can be damaged.
    • Separate the housing from the motherboard.
    • Be careful while separating the housing. The power and volume buttons are easily separated from the housing and can be damaged.
  9. The Motherboard is the brain of the phone, handle with care. Using the spudger, separate the motherboard from the keyboard frame.
    • The Motherboard is the brain of the phone, handle with care.
    • Using the spudger, separate the motherboard from the keyboard frame.
    • Tilt the motherboard upward from the side of the charger connection as shown in the picture.
  10. Using the spudger, gently disconnect the two motherboard connections. Once the motherboard is separated from the phone place it in a safe place.
    • Using the spudger, gently disconnect the two motherboard connections.
    • Once the motherboard is separated from the phone place it in a safe place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Javier
530 Reputatie
4 handleidingen geschreven
USF Tampa, Team 5-1, Mcgee Fall 2014 Lid van USF Tampa, Team 5-1, Mcgee Fall 2014
USFT-MCGEE-F14S5G1
5 Leden
5 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 757
