Ga door naar hoofdinhoud
Motorola Droid 4 Motherboard Housing Replacement
Wat je nodig hebt
  1. Motorola Droid 4 Motherboard Housing Replacement, Removing Rear Panel: stap 1, afbeelding 1 van 3 Motorola Droid 4 Motherboard Housing Replacement, Removing Rear Panel: stap 1, afbeelding 2 van 3 Motorola Droid 4 Motherboard Housing Replacement, Removing Rear Panel: stap 1, afbeelding 3 van 3
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 Motherboard Housing Replacement, Battery: stap 2, afbeelding 1 van 1
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
  3. Motorola Droid 4 Motherboard Housing Replacement: stap 3, afbeelding 1 van 2 Motorola Droid 4 Motherboard Housing Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    T5 Torx Screwdriver
    $5.49
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
  4. Motorola Droid 4 Motherboard Housing Replacement, Camera Cover Removal: stap 4, afbeelding 1 van 3 Motorola Droid 4 Motherboard Housing Replacement, Camera Cover Removal: stap 4, afbeelding 2 van 3 Motorola Droid 4 Motherboard Housing Replacement, Camera Cover Removal: stap 4, afbeelding 3 van 3
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
  5. Motorola Droid 4 Motherboard Housing Replacement, Remove Screws: stap 5, afbeelding 1 van 2 Motorola Droid 4 Motherboard Housing Replacement, Remove Screws: stap 5, afbeelding 2 van 2
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
  6. Motorola Droid 4 Motherboard Housing Replacement, Remove Bezel: stap 6, afbeelding 1 van 3 Motorola Droid 4 Motherboard Housing Replacement, Remove Bezel: stap 6, afbeelding 2 van 3 Motorola Droid 4 Motherboard Housing Replacement, Remove Bezel: stap 6, afbeelding 3 van 3
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
  7. Motorola Droid 4 Motherboard Housing Replacement, Removing screws: stap 7, afbeelding 1 van 2 Motorola Droid 4 Motherboard Housing Replacement, Removing screws: stap 7, afbeelding 2 van 2
    • Remove the 12 screws holding the housing in place using a T5 Torx screwdriver.
    • Follow the red circles, indicated in the picture, to locate the screws.
    • The 12 screws are (silver) philips 2.5mm
  8. Motorola Droid 4 Motherboard Housing Replacement, Separation of the Housing from the Motherboard: stap 8, afbeelding 1 van 3 Motorola Droid 4 Motherboard Housing Replacement, Separation of the Housing from the Motherboard: stap 8, afbeelding 2 van 3 Motorola Droid 4 Motherboard Housing Replacement, Separation of the Housing from the Motherboard: stap 8, afbeelding 3 van 3
    • Separate the housing from the motherboard.
    • Be careful while separating the housing. The power and volume buttons are easily separated from the housing and can be damaged.
Conclusie
Javier
533 Reputatie
4 handleidingen geschreven
USF Tampa, Team 5-1, Mcgee Fall 2014 Lid van USF Tampa, Team 5-1, Mcgee Fall 2014
USFT-MCGEE-F14S5G1
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 11
Altijd: 541
