Ga door naar hoofdinhoud
Motorola Defy XT Screen Replacement
Wat je nodig hebt
  1. Motorola Defy XT Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Screen Replacement: stap 2, afbeelding 1 van 1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
  3. Motorola Defy XT Screen Replacement: stap 3, afbeelding 1 van 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
  4. Motorola Defy XT Screen Replacement, SD Card: stap 4, afbeelding 1 van 1
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
  5. Motorola Defy XT Screen Replacement, Screen: stap 5, afbeelding 1 van 2 Motorola Defy XT Screen Replacement, Screen: stap 5, afbeelding 2 van 2
    • Use the Torx T4 screwdriver to remove the six 3 mm screws from the back case.
  6. Motorola Defy XT Screen Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to pop the volume buttons off from the side of the phone.
  7. Motorola Defy XT Screen Replacement: stap 7, afbeelding 1 van 1
    • Wedge the plastic opening tool between the plastic layer and the shiny front cover.
  8. Motorola Defy XT Screen Replacement: stap 8, afbeelding 1 van 1
    • Slide the plastic opening tool along the edge, wedging the the two pieces apart.
    • Potential for device damage: Do not completely separate the two pieces; there are still internal components that need to be disconnected.
  9. Motorola Defy XT Screen Replacement: stap 9, afbeelding 1 van 2 Motorola Defy XT Screen Replacement: stap 9, afbeelding 2 van 2
    • Slide the screen out and disconnect the ribbon cable connecting the display to the motherboard by pulling straight outward.
    • Potential for device damage: Be careful when sliding out the screen because the front case and the motherboard are still connected by two other ribbon cables.
  10. Motorola Defy XT Screen Replacement: stap 10, afbeelding 1 van 2 Motorola Defy XT Screen Replacement: stap 10, afbeelding 2 van 2
    • Set the old screen aside and replace it with your new screen.
Conclusie
Oscar Camacho
89 Reputatie
1 Handleiding geschreven
Cal Poly, Team 2-22, Maness Spring 2013 Lid van Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 3,092
