Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Motorola Defy XT Battery Replacement
Wat je nodig hebt
  1. Motorola Defy XT Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Motorola Defy XT Battery Replacement: stap 2, afbeelding 1 van 1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone. Remove the back cover and set it aside.
  3. Motorola Defy XT Battery Replacement: stap 3, afbeelding 1 van 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
Conclusie
Dorian Capps
64 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-22, Maness Spring 2013 Lid van Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Leden
8 handleidingen geschreven
Één opmerking
There isn't really much need for guidance on replacing the battery, but it would be helpful if you could provide some details on how long it takes for the first charge after replacement. I connected my charger after replacing the battery and it only lights up the back/menu/home keys below the screen - no indication of battery charging etc. and the phone cannot be powered yet. It's been charging for well over half an hour. Any advice?
shaunschon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 1,664
