Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Onderdelen
Geen onderdelen opgegeven.
  1. Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
  2. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  3. Once wedged in the opening, slide the opening tool sideways around the sides of the phone. Remove the back cover and set it aside.
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone. Remove the back cover and set it aside.
  4. Insert the opening tool between the battery and the battery holder and wedge the battery out.
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
Conclusie
Dorian Capps
64 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-22, Maness Spring 2013 Lid van Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Leden
4 handleidingen geschreven
Één commentaar
There isn't really much need for guidance on replacing the battery, but it would be helpful if you could provide some details on how long it takes for the first charge after replacement. I connected my charger after replacing the battery and it only lights up the back/menu/home keys below the screen - no indication of battery charging etc. and the phone cannot be powered yet. It's been charging for well over half an hour. Any advice?
shaunschon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,466
