Ga door naar hoofdinhoud
Motorola Defy Earpiece Speaker Replacement
Wat je nodig hebt
  1. Motorola Defy Earpiece Speaker Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Using the screwdriver and the T-5 bit, unscrew the seven 5 mm screws around the outside of the phone.
  2. Motorola Defy Earpiece Speaker Replacement: stap 2, afbeelding 1 van 2 Motorola Defy Earpiece Speaker Replacement: stap 2, afbeelding 2 van 2
    • Remove the back cover of the phone by sliding the bottom black button to the unlock position and lifting it up.
  3. Motorola Defy Earpiece Speaker Replacement, Battery: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to pry the battery out of the phone.
  4. Motorola Defy Earpiece Speaker Replacement, Midframe: stap 4, afbeelding 1 van 1
    • Unscrew the two silver screws located at the top of the back of the phone.
  5. Motorola Defy Earpiece Speaker Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to gently pry the midframe from the rest of the phone.
  6. Motorola Defy Earpiece Speaker Replacement, Motherboard: stap 6, afbeelding 1 van 2 Motorola Defy Earpiece Speaker Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Use metal spudger to pry off the middle yellow flap carefully.
  7. Motorola Defy Earpiece Speaker Replacement: stap 7, afbeelding 1 van 3 Motorola Defy Earpiece Speaker Replacement: stap 7, afbeelding 2 van 3 Motorola Defy Earpiece Speaker Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers again to pry off the second yellow flap carefully.
  8. Motorola Defy Earpiece Speaker Replacement: stap 8, afbeelding 1 van 1
    • The motherboard is the whole green board. Pry it off carefully with tweezers from the sides and place it aside.
  9. Motorola Defy Earpiece Speaker Replacement, Remove the earpiece speaker: stap 9, afbeelding 1 van 2 Motorola Defy Earpiece Speaker Replacement, Remove the earpiece speaker: stap 9, afbeelding 2 van 2
    Koop
    • Once the motherboard is removed, use either the metal tweezers or the metal spudger to remove the speaker by prying it as shown.
    • The speaker is glued to its position, thus you will have to glue the new one back on.
    • The speaker must be pried off carefully. It is very delicate.
Conclusie
Andres
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team 14-2, Leahy Fall 2014 Lid van USF Tampa, Team 14-2, Leahy Fall 2014
USFT-LEAHY-F14S14G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 650
