Ga door naar hoofdinhoud
Motorola DROID RAZR MAXX Camera Cover Replacement
Wat je nodig hebt
  1. Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: stap 1, afbeelding 1 van 2 Motorola DROID RAZR MAXX Camera Cover Replacement, Camera Cover: stap 1, afbeelding 2 van 2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola DROID RAZR MAXX Camera Cover Replacement: stap 2, afbeelding 1 van 2 Motorola DROID RAZR MAXX Camera Cover Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola DROID RAZR MAXX Camera Cover Replacement: stap 3, afbeelding 1 van 3 Motorola DROID RAZR MAXX Camera Cover Replacement: stap 3, afbeelding 2 van 3 Motorola DROID RAZR MAXX Camera Cover Replacement: stap 3, afbeelding 3 van 3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
  4. Motorola DROID RAZR MAXX Camera Cover Replacement: stap 4, afbeelding 1 van 1
    • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
    • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Govind
130 Reputatie
1 Handleiding geschreven
USF Tampa, Team 14-6, Leahy Fall 2014 Lid van USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 745
