Ga door naar hoofdinhoud
Motorola Cliq Rear Speakers Replacement
Wat je nodig hebt
  1. Motorola Cliq Rear Speakers Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola Cliq Rear Speakers Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
  2. Motorola Cliq Rear Speakers Replacement: stap 2, afbeelding 1 van 2 Motorola Cliq Rear Speakers Replacement: stap 2, afbeelding 2 van 2
    • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
  3. Motorola Cliq Rear Speakers Replacement, Rear Casing: stap 3, afbeelding 1 van 3 Motorola Cliq Rear Speakers Replacement, Rear Casing: stap 3, afbeelding 2 van 3 Motorola Cliq Rear Speakers Replacement, Rear Casing: stap 3, afbeelding 3 van 3
    • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
  4. Motorola Cliq Rear Speakers Replacement: stap 4, afbeelding 1 van 1
    • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
  5. Motorola Cliq Rear Speakers Replacement: stap 5, afbeelding 1 van 3 Motorola Cliq Rear Speakers Replacement: stap 5, afbeelding 2 van 3 Motorola Cliq Rear Speakers Replacement: stap 5, afbeelding 3 van 3
    • Turn the phone over and slide out the keyboard.
    • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
    • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
  6. Motorola Cliq Rear Speakers Replacement: stap 6, afbeelding 1 van 1
    • Carefully separate the back casing from the rest of the phone.
  7. Motorola Cliq Rear Speakers Replacement: stap 7, afbeelding 1 van 2 Motorola Cliq Rear Speakers Replacement: stap 7, afbeelding 2 van 2
    • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
  8. Motorola Cliq Rear Speakers Replacement: stap 8, afbeelding 1 van 3 Motorola Cliq Rear Speakers Replacement: stap 8, afbeelding 2 van 3 Motorola Cliq Rear Speakers Replacement: stap 8, afbeelding 3 van 3
    • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
    • The rear casing and the rest of the phone should now be completely separated.
  9. Motorola Cliq Rear Speakers Replacement, Rear Speakers: stap 9, afbeelding 1 van 2 Motorola Cliq Rear Speakers Replacement, Rear Speakers: stap 9, afbeelding 2 van 2
    • Insert a plastic opening tool in the gap right above the speakers.
    • Pry upwards to lift the speaker out of its bracket.
    • The speakers are glued down and will cause a bit of resistance when prying.
    • Do not pry anywhere else because it may lead to the bracket around the speaker to break.
  10. Motorola Cliq Rear Speakers Replacement: stap 10, afbeelding 1 van 2 Motorola Cliq Rear Speakers Replacement: stap 10, afbeelding 2 van 2
    • With your fingers, carefully remove the speaker.
    • Repeat this process to remove the remaining speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tony Tran
64 Reputatie
8 handleidingen geschreven
Cal Poly, Team 10-42, Amido Spring 2013 Lid van Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 475
