Ga door naar hoofdinhoud
Motorola California Mobile Phone Rear Casing Replacement
Wat je nodig hebt
  1. Motorola California Mobile Phone Rear Casing Replacement, Rear Casing: stap 1, afbeelding 1 van 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Rear Casing Replacement: stap 2, afbeelding 1 van 1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Rear Casing Replacement: stap 3, afbeelding 1 van 1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the old rear casing away from the rest of the device.
  4. Motorola California Mobile Phone Rear Casing Replacement: stap 4, afbeelding 1 van 1
    • Locate the four holes on the new rear casing.
    • Align the holes in the new rear casing with the clips attached the to front casing.
    • Simultaneously insert all four clips.
    • Push down firmly until you hear the clips click into place.
  5. Motorola California Mobile Phone Rear Casing Replacement: stap 5, afbeelding 1 van 1
    • Find a thin and sturdy screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the new key pad guard to the rear casing.
    • Use the screwdriver to push the rods away from each other until they click into their locked position.
Conclusie
Andrew Lam
53 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-46, Regan Spring 2012 Lid van Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 1,202
