Ga door naar hoofdinhoud
Motorola California Mobile Phone Motherboard Replacement
Wat je nodig hebt
    1. Motorola California Mobile Phone Motherboard Replacement, Motorola California Mobile Phone Teardown: stap 1, afbeelding 1 van 1
      • Remove the battery by sliding it down the rails to which it is connected.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola California Mobile Phone Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Find a flat head or Phillips head screwdriver.
      • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
      • Use the screwdriver to push the rods towards each other until they click out of their locked position.
      • Note: This may require a large amount of force.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola California Mobile Phone Motherboard Replacement: stap 3, afbeelding 1 van 1
      • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
      • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
      • Remove the key guard from the rear casing by taking it out of its position.
      Vraag FixBot
      Voeg opmerking toe
    4. Motorola California Mobile Phone Motherboard Replacement: stap 4, afbeelding 1 van 1
      • Locate and unplug the black component of the antenna from the motherboard.
      • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
      Vraag FixBot
      Voeg opmerking toe
    5. Motorola California Mobile Phone Motherboard Replacement: stap 5, afbeelding 1 van 1
      • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. Motorola California Mobile Phone Motherboard Replacement: stap 6, afbeelding 1 van 1
      • Lift the motherboard out of its location in the front casing.
      • Do this slowly and gently so that none of the motherboard's components are damaged.
      Vraag FixBot
      Voeg opmerking toe
    1. Motorola California Mobile Phone Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 1
      • With your new motherboard, hold the LCD side of the motherboard face down. Align the four clips on the front casing with the four notches on the motherboard.
      • While doing so, insert the LCD into the compartment in the front casing.
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola California Mobile Phone Motherboard Replacement: stap 8, afbeelding 1 van 1
      • Press firmly on the motherboard until it is snug inside the casing.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Andrew Lam
53 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-46, Regan Spring 2012 Lid van Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Leden
72 handleidingen geschreven
1Gids Commentaar
Nice, thanks.
Daniel - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 45
Altijd: 3,551
