Ga door naar hoofdinhoud
Motorola California Mobile Phone Keypad Guard Replacement
Wat je nodig hebt
  1. Motorola California Mobile Phone Keypad Guard Replacement, Keypad Guard: stap 1, afbeelding 1 van 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Keypad Guard Replacement: stap 2, afbeelding 1 van 1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Keypad Guard Replacement: stap 3, afbeelding 1 van 1
    • Slide off the antenna guard.
    • Locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the old key guard from the rear casing by taking it out of its position.
  4. Motorola California Mobile Phone Keypad Guard Replacement: stap 4, afbeelding 1 van 1
    • Locate the circular extensions protruding from the top of your new key guard.
    • Push inwards on the small tabs on the side of the protrusions until they are no longer sticking out.
    • Note: This may require a strong push.
  5. Motorola California Mobile Phone Keypad Guard Replacement: stap 5, afbeelding 1 van 1
    • Put the back case down on a table in front of you with the bottom of the phone close to you.
    • Put the key guard's tabs into the corresponding tabs on the bottom of the rear casing.
    • While the key guard's tabs are in the rear casing, put the rear casing's tabs into the bottom of the front casing.
  6. Motorola California Mobile Phone Keypad Guard Replacement: stap 6, afbeelding 1 van 1
    • To join the 3 pieces together, push the front and rear casing together so that the clips on the front casing lock into the holes on the rear casing.
    • Slide the antenna guard on.
  7. Motorola California Mobile Phone Keypad Guard Replacement: stap 7, afbeelding 1 van 1
    • Locate the holes that connect the keypad guard to the rear casing.
    • Find a thin and sturdy screwdriver.
    • Use the screwdriver to push the rods away from each other until they click into a locked position.
    • Note: During usage, the key guard will not snap into place if it has not been locked into position.
Conclusie
Andrew Caddell
10 Reputatie
1 Handleiding geschreven
Cal Poly, Team 9-46, Regan Spring 2012 Lid van Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 37
Altijd: 3,700
