Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Use this guide to replace the rubber keypad on your Motorola C350.
  1. Use your finger to press the button and free the device rear case. You may have to force it a bit more to free its bottom if you open it for the first time.
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. slide the black button to free the battery so you can grab it with your other hand.
    • slide the black button to free the battery so you can grab it with your other hand.
  3. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components. You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  4. Use your thumb to gently peel the keyboard off the front case.
    • Use your thumb to gently peel the keyboard off the front case.
    • Be careful, the plastic on which the keyboard is stuck is pretty fragile.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Vincent Monteil
6.605 Reputatie
19 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 248
