Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Begin by flipping your phone over so that the back cover is facing up. Apply force to the back cover and simultaneously slide the cover down. Note: Applying pressure on the ridges will make it easier to remove the cover.
    • Begin by flipping your phone over so that the back cover is facing up.
    • Apply force to the back cover and simultaneously slide the cover down.
    • Note: Applying pressure on the ridges will make it easier to remove the cover.
  2. Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery. Lift and remove the battery. Lift and remove the battery.
    • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Lift and remove the battery.
  3. Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water. Gently slide the SIM card out and lift to remove it from the phone. Gently slide the SIM card out and lift to remove it from the phone.
    • Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water.
    • Gently slide the SIM card out and lift to remove it from the phone.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Use a Torx T-5 screwdriver to remove the screws on the back of the phone. The screws are 6.86 mm long and 1.61 mm in diameter. The screws are 6.86 mm long and 1.61 mm in diameter.
    • Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
    • The screws are 6.86 mm long and 1.61 mm in diameter.
  6. Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone. Repeat for the other side. Repeat for the other side.
    • Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone.
    • Repeat for the other side.
  7. Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top. Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together. Release a total of six hooks from the sides and top to free the phone into two halves.
    • Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
    • Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
    • Release a total of six hooks from the sides and top to free the phone into two halves.
  8. Using a Torx T-5 screwdriver remove the screws at the top of the phone. The screws are 6.86 mm long and 1.61mm in diameter. The screws are 6.86 mm long and 1.61mm in diameter.
    • Using a Torx T-5 screwdriver remove the screws at the top of the phone.
    • The screws are 6.86 mm long and 1.61mm in diameter.
  9. Use plastic opening tools to free the circuit board from the case. There are two hooks (one on each side) holding the circuit board into the case. Then grip the circuit board and lift to remove the circuit board from the case.
    • Use plastic opening tools to free the circuit board from the case.
    • There are two hooks (one on each side) holding the circuit board into the case.
    • Then grip the circuit board and lift to remove the circuit board from the case.
  10. Using your hands or the pry tool, gently lift the vibration mechanism out of the rear casing. Using your hands or the pry tool, gently lift the vibration mechanism out of the rear casing.
    • Using your hands or the pry tool, gently lift the vibration mechanism out of the rear casing.
Conclusie
Kyle Olbrich
30 Reputatie
4 handleidingen geschreven
Clemson, Team 2-2, Benson Spring 2012 Lid van Clemson, Team 2-2, Benson Spring 2012
CLEM-BENSON-S12S2G2
3 Leden
15 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,000
