Ga door naar hoofdinhoud
Motorola C139 Rear Casing Replacement
Wat je nodig hebt
  1. Motorola C139 Rear Casing Replacement, Battery: stap 1, afbeelding 1 van 3 Motorola C139 Rear Casing Replacement, Battery: stap 1, afbeelding 2 van 3 Motorola C139 Rear Casing Replacement, Battery: stap 1, afbeelding 3 van 3
    • Begin by flipping your phone over so that the back cover is facing up.
    • Apply force to the back cover and simultaneously slide the cover down.
    • Note: Applying pressure on the ridges will make it easier to remove the cover.
  2. Motorola C139 Rear Casing Replacement: stap 2, afbeelding 1 van 3 Motorola C139 Rear Casing Replacement: stap 2, afbeelding 2 van 3 Motorola C139 Rear Casing Replacement: stap 2, afbeelding 3 van 3
    • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Lift and remove the battery.
  3. Motorola C139 Rear Casing Replacement, Rear Casing: stap 3, afbeelding 1 van 3 Motorola C139 Rear Casing Replacement, Rear Casing: stap 3, afbeelding 2 van 3 Motorola C139 Rear Casing Replacement, Rear Casing: stap 3, afbeelding 3 van 3
    • Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
    • The screws are 6.86 mm long and 1.61 mm in diameter.
  4. Motorola C139 Rear Casing Replacement: stap 4, afbeelding 1 van 3 Motorola C139 Rear Casing Replacement: stap 4, afbeelding 2 van 3 Motorola C139 Rear Casing Replacement: stap 4, afbeelding 3 van 3
    • Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone.
    • Repeat for the other side.
  5. Motorola C139 Rear Casing Replacement: stap 5, afbeelding 1 van 3 Motorola C139 Rear Casing Replacement: stap 5, afbeelding 2 van 3 Motorola C139 Rear Casing Replacement: stap 5, afbeelding 3 van 3
    • Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
    • Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
    • Release a total of six hooks from the sides and top to free the phone into two halves.
  6. Motorola C139 Rear Casing Replacement: stap 6, afbeelding 1 van 3 Motorola C139 Rear Casing Replacement: stap 6, afbeelding 2 van 3 Motorola C139 Rear Casing Replacement: stap 6, afbeelding 3 van 3
    • Using a Torx T-5 screwdriver remove the screws at the top of the phone.
    • The screws are 6.86 mm long and 1.61mm in diameter.
  7. Motorola C139 Rear Casing Replacement: stap 7, afbeelding 1 van 3 Motorola C139 Rear Casing Replacement: stap 7, afbeelding 2 van 3 Motorola C139 Rear Casing Replacement: stap 7, afbeelding 3 van 3
    • Use plastic opening tools to free the circuit board from the case.
    • There are two hooks (one on each side) holding the circuit board into the case.
    • Then grip the circuit board and lift to remove the circuit board from the case.
Conclusie
Christopher Stubbs
77 Reputatie
4 handleidingen geschreven
Clemson, Team 2-2, Benson Spring 2012 Lid van Clemson, Team 2-2, Benson Spring 2012
CLEM-BENSON-S12S2G2
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 27
Altijd: 1,166
