Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
Inleiding
Ga naar stap 1 ↓This process involves first removing the battery, outer case, and motherboard. After, the keypad can be easily removed.
Wat je nodig hebt
Gereedschap
Hold the phone and pull the back latch down towards the bottom.
Remove the back panel by releasing the latch and lifting from the top.
Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
Once the screws are removed, simply lift the back panel off
Peel the keypad from the front case.
The keypad may be stuck either to the logic board, below the screen, or the phone case itself.
