Inleiding
Use this guide to replace the motherboard in your Moto G6 Play.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
While this guide may include images of the device with the battery removed, it is not necessary to remove the battery to replace the motherboard.
Wat je nodig hebt
Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the upper right edge of the phone.
Press the tool into the hole to eject the tray.
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Gereedschap gebruikt in deze stap:Tesa 61395 Tape$5.99
If the glass remains stuck, re-heat and slice any remaining adhesive repeatedly as needed.
Lift the rear glass carefully, making sure it's fully separated from any adhesive.
Open the rear glass.
Use a Phillips screwdriver to remove the two screws securing the fingerprint sensor cable retention bracket:
One silver 1.5 mm screw
One gold 3.5 mm screw
Use a Phillips screwdriver to remove the fifteen gold 3.5 mm screws securing the plastic midframe.
Insert a spudger into the notch on the upper right edge of the midframe.
Pry the midframe up to release the clips securing it to the device's aluminum frame.
Remove the plastic midframe.
Use a pair of tweezers to carefully remove the tape covering the camera module connector.
Insert the pointed end of a spudger underneath the bottom left corner of the earpiece speaker and pry it up.
Remove the earpiece speaker.
Use a spudger to pry up and disconnect the daughterboard flex cable from the motherboard.
Use the pointed end of a spudger to flip up the locking flap on the side button ZIF connector.
Use a Phillips screwdriver to remove the two silver 2 mm screws securing the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto G6 Play Answers Community for help.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Hi guys my problem with my Motorola g6 play is display light it is verry low I tried to sett it but still no light.
