Ga door naar hoofdinhoud
Moto G4 Rear-facing Camera Replacement
Wat je nodig hebt
  1. Moto G4 Rear-facing Camera  Replacement, Back Cover: stap 1, afbeelding 1 van 3 Moto G4 Rear-facing Camera  Replacement, Back Cover: stap 1, afbeelding 2 van 3 Moto G4 Rear-facing Camera  Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Moto G4 Rear-facing Camera  Replacement: stap 2, afbeelding 1 van 2 Moto G4 Rear-facing Camera  Replacement: stap 2, afbeelding 2 van 2
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Moto G4 Rear-facing Camera  Replacement: stap 3, afbeelding 1 van 3 Moto G4 Rear-facing Camera  Replacement: stap 3, afbeelding 2 van 3 Moto G4 Rear-facing Camera  Replacement: stap 3, afbeelding 3 van 3
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Moto G4 Rear-facing Camera  Replacement: stap 4, afbeelding 1 van 2 Moto G4 Rear-facing Camera  Replacement: stap 4, afbeelding 2 van 2
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Moto G4 Rear-facing Camera  Replacement, Midframe: stap 5, afbeelding 1 van 3 Moto G4 Rear-facing Camera  Replacement, Midframe: stap 5, afbeelding 2 van 3 Moto G4 Rear-facing Camera  Replacement, Midframe: stap 5, afbeelding 3 van 3
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Moto G4 Rear-facing Camera  Replacement: stap 6, afbeelding 1 van 2 Moto G4 Rear-facing Camera  Replacement: stap 6, afbeelding 2 van 2
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Moto G4 Rear-facing Camera  Replacement: stap 7, afbeelding 1 van 1
    • Remove the rubber cover.
  8. Moto G4 Rear-facing Camera  Replacement: stap 8, afbeelding 1 van 2 Moto G4 Rear-facing Camera  Replacement: stap 8, afbeelding 2 van 2
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Moto G4 Rear-facing Camera  Replacement: stap 9, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  10. Moto G4 Rear-facing Camera  Replacement: stap 10, afbeelding 1 van 1
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  11. Moto G4 Rear-facing Camera  Replacement: stap 11, afbeelding 1 van 1
    • Remove the midframe.
  12. Moto G4 Rear-facing Camera  Replacement, Battery Disconnection: stap 12, afbeelding 1 van 2 Moto G4 Rear-facing Camera  Replacement, Battery Disconnection: stap 12, afbeelding 2 van 2
    • Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
    • Gently pry straight up to disconnect the battery.
    • Pry only from the side where the wires attach to the connector—if you pry anywhere else, you may break the socket.
    • During reassembly, align the connector in its socket and then press straight down to reconnect it, wiggling slightly as you press to help it seat correctly.
  13. Moto G4 Rear-facing Camera  Replacement, Motherboard: stap 13, afbeelding 1 van 2 Moto G4 Rear-facing Camera  Replacement, Motherboard: stap 13, afbeelding 2 van 2
    • Peel off any tape securing the battery wires, and then push the battery wires towards the battery to de-route them from the black bracket on the motherboard.
  14. Moto G4 Rear-facing Camera  Replacement: stap 14, afbeelding 1 van 1
    • It's not necessary to remove the battery in order to remove or replace the motherboard. You can safely ignore the fact that the battery is missing in the remaining images in this guide.
    • Peel up and remove the black rubber cover from the charging port and vibration motor connector.
  15. Moto G4 Rear-facing Camera  Replacement: stap 15, afbeelding 1 van 2 Moto G4 Rear-facing Camera  Replacement: stap 15, afbeelding 2 van 2
    • Insert the point of your spudger underneath the vibration motor, and gently pry up to separate it from the frame.
  16. Moto G4 Rear-facing Camera  Replacement: stap 16, afbeelding 1 van 1
    • Peel up the copper tape covering the display connector.
    • This tape provides protection from electromagnetic interference. Keep it in one piece if possible, and carefully fold it back into position when your repair is complete.
  17. Moto G4 Rear-facing Camera  Replacement: stap 17, afbeelding 1 van 2 Moto G4 Rear-facing Camera  Replacement: stap 17, afbeelding 2 van 2
    • Use your spudger to disconnect the display by prying its connector straight up from the motherboard, on the edge nearest the side of the phone.
  18. Moto G4 Rear-facing Camera  Replacement: stap 18, afbeelding 1 van 2 Moto G4 Rear-facing Camera  Replacement: stap 18, afbeelding 2 van 2
    • Pry up with your spudger to flip open the locking flap on the headphone jack's ZIF connector.
    • It's possible to disconnect the headphone jack at this point by pulling its orange flex cable straight out of the ZIF socket, but it's easy to tear the cable if you're not careful. For a better method, continue with the steps below.
  19. Moto G4 Rear-facing Camera  Replacement: stap 19, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the two bronze-colored, 2.4 mm screws securing the motherboard.
  20. Moto G4 Rear-facing Camera  Replacement: stap 20, afbeelding 1 van 3 Moto G4 Rear-facing Camera  Replacement: stap 20, afbeelding 2 van 3 Moto G4 Rear-facing Camera  Replacement: stap 20, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Grasping the motherboard by its edges, left the bottom end up at an angle, while keeping the top edge close to the phone.
    • Use your spudger to pry up the front-facing camera and make sure it separates safely from the frame. The camera can remain attached to the motherboard.
    • Using your tweezers, grasp the headphone jack flex cable and carefully pull it out of its socket as you remove the motherboard.
    • Remove the motherboard.
    • If you feel any resistance, stop. Make sure there are no components still holding the frame to the motherboard.
    • If desired, remove the remaining components from the motherboard (cameras and vibration motor).
  21. Moto G4 Rear-facing Camera  Replacement, Rear-facing Camera: stap 22, afbeelding 1 van 1
    • Flip motherboard over to access the rear camera.
    • Peel up orange tape and remove to access the top of rear camera motherboard clamp.
    • Flip up the black tab on the ZIF connector to detach the rear camera.
  22. Moto G4 Rear-facing Camera  Replacement: stap 23, afbeelding 1 van 1
    • Remove rear camera from motherboard.
  23. Moto G4 Rear-facing Camera  Replacement: stap 24, afbeelding 1 van 3 Moto G4 Rear-facing Camera  Replacement: stap 24, afbeelding 2 van 3 Moto G4 Rear-facing Camera  Replacement: stap 24, afbeelding 3 van 3
    • Separate the black plastic cover from the broken rear camera you removed.
    • Glue black plastic cover onto the new replacement rear camera.
Conclusie
Nathan Granger
202 Reputatie
2 handleidingen geschreven
USF Tampa, Team S15-G3, Boczar Spring 2018 Lid van USF Tampa, Team S15-G3, Boczar Spring 2018
USFT-BOCZAR-S18S15G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 541
