Ga door naar hoofdinhoud
Motherboard Replacement
Wat je nodig hebt
  1. Motherboard Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Motherboard Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Motherboard Replacement: stap 3, afbeelding 1 van 2 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Motherboard Replacement, Motherboard Cover: stap 4, afbeelding 1 van 3 Motherboard Replacement, Motherboard Cover: stap 4, afbeelding 2 van 3 Motherboard Replacement, Motherboard Cover: stap 4, afbeelding 3 van 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Motherboard Replacement, Battery: stap 5, afbeelding 1 van 2 Motherboard Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
  6. Motherboard Replacement: stap 6, afbeelding 1 van 2 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
  7. Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
  8. Motherboard Replacement, Speakers: stap 8, afbeelding 1 van 2 Motherboard Replacement, Speakers: stap 8, afbeelding 2 van 2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  9. Motherboard Replacement: stap 9, afbeelding 1 van 2 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  10. Motherboard Replacement: stap 10, afbeelding 1 van 2 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
  11. Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 2 Motherboard Replacement, Motherboard: stap 11, afbeelding 2 van 2
    • Remove these two 4.5 mm Philips silver screws holding down the motherboard.
    • The motherboard should be able to be lifted right out of the housing.
  12. Motherboard Replacement: stap 12, afbeelding 1 van 3 Motherboard Replacement: stap 12, afbeelding 2 van 3 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • You will finds a ribbon cable connecting the motherboard to the control interface circuit board.
    • Using a spudger or plastic opening tool, lift flap on the ribbon cable ZIF connector.
    • Using a plastic pry tool or fine tip plastic tool to open the clamp.
    • Using the tool, try lifting the clamp up on either location, noted by the blue arrow.
    • The ribbon should pop out, if not you should be able to slide it out from the clamp.
Conclusie
Samuel Knapik
121 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 3-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G2
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 344
