Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
First remove the rear or the iron using the flathead screwdriver.
Next remove the screws from the base. (see arrows for location)
To free the long cable remove from terminal block at rear.
At the front of the iron pull out the buttons for the steam and water.
Next unclip the button holder (red circle) by undoing the screws (black circle)
Next remove the bridge clip from the arrows position.
Next remove the inner button (black circle)
Now remove the centre screw (red arrow)
Disassemble the plug
First remove the casing.
Now remove the wires from the pins.
Next remove the pins.
Remove front of the iron by undoing the screw (arrow) by first taking off cover cap.
Next take out round selector, this is simply clipped so can be pulled out with pliers.
Next remove the washer parts at the front of the iron.
Take the tubing off.
Remove the seals for the water pump.
Now take pumps out.
Remove the screw (circled) this will lead to the separation of the base and the top.
Remove the top of the iron to reveal the under parts.
Now remove the rubber seals from the plate.
Take out the screws linking to the stainless steel base.
Remove the terminal block from the wires.
Next take off the black section of the iron.
