Inleiding
If you are hearing any high-pitched noises or having any suction issues while using the floor brush attachment, you may have a loose motor connection to the floor brush. The motor in the floor brush attachment of the vacuum powers the floor brush and the suction. Here is a guide on how to replace the motor in the Moosoo XL-618A vacuum.
Wat je nodig hebt
Remove the eight 11 mm screws on the bottom of the vacuum with the Phillips #1 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
