Ga door naar hoofdinhoud
Moosoo XL-618A Motherboard Replacement
Wat je nodig hebt
  1. Moosoo XL-618A Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Moosoo XL-618A Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Remove all nine 16 mm screws from the top motor with the Phillips #1 screwdriver.
  2. Moosoo XL-618A Motherboard Replacement: stap 2, afbeelding 1 van 2 Moosoo XL-618A Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Using a spudger, open the device along the small lines that are visible to you. Go on to pry off all other detachable objects and set aside.
    • Make sure to not go too far as this could further damage the device.
  3. Moosoo XL-618A Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Pull the motherboard underneath the top handle of the top motor out and remove the connected wires. Then replace it with a new motherboard.
    • Be careful with the wires so that they don't get damaged in the process.
Conclusie
Ashtyn
489 Reputatie
3 handleidingen geschreven
Utah Tech University, Team 1-1, McMurrin Fall 2023 Lid van Utah Tech University, Team 1-1, McMurrin Fall 2023
UTAHTECH-MCMURRIN-F23S1G1
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 82
Altijd: 335
