Ga door naar hoofdinhoud
Montgomery Ward GEN-39500 Subwoofer Replacement
Wat je nodig hebt
  1. Montgomery Ward GEN-39500 Subwoofer Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Subwoofer Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Subwoofer Replacement: stap 3, afbeelding 1 van 2 Montgomery Ward GEN-39500 Subwoofer Replacement: stap 3, afbeelding 2 van 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Subwoofer Replacement, Subwoofer: stap 4, afbeelding 1 van 2 Montgomery Ward GEN-39500 Subwoofer Replacement, Subwoofer: stap 4, afbeelding 2 van 2
    • Unsolder the wires leading to and from the subwoofer.
  5. Montgomery Ward GEN-39500 Subwoofer Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the four 12.5 mm Phillips screws holding the subwoofer in place.
    • One of the screws holds down a metal cable organizer. For better cable organization after reassembly keep track of this organizer.
  6. Montgomery Ward GEN-39500 Subwoofer Replacement: stap 6, afbeelding 1 van 1
    • Remove the subwoofer.
    • The process is the same for both sides.
Conclusie
Dustin Platt
931 Reputatie
6 handleidingen geschreven
Cal Poly, Team 12-5, Lancaster Spring 2015 Lid van Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 9
Altijd: 126
