Ga door naar hoofdinhoud
Montgomery Ward GEN-39500 Internal Power Supply Replacement
Wat je nodig hebt
  1. Montgomery Ward GEN-39500 Internal Power Supply Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Internal Power Supply Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Internal Power Supply Replacement: stap 3, afbeelding 1 van 2 Montgomery Ward GEN-39500 Internal Power Supply Replacement: stap 3, afbeelding 2 van 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Internal Power Supply Replacement, Internal Power Supply: stap 4, afbeelding 1 van 1
    • Unscrew the six 10 mm Phillips screws holding the mounting plate in place.
  5. Montgomery Ward GEN-39500 Internal Power Supply Replacement: stap 5, afbeelding 1 van 3 Montgomery Ward GEN-39500 Internal Power Supply Replacement: stap 5, afbeelding 2 van 3 Montgomery Ward GEN-39500 Internal Power Supply Replacement: stap 5, afbeelding 3 van 3
    • Unsolder the wires connecting the power supply unit to the battery container.
  6. Montgomery Ward GEN-39500 Internal Power Supply Replacement: stap 6, afbeelding 1 van 1
    • Remove the power supply unit.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dustin Platt
931 Reputatie
6 handleidingen geschreven
Cal Poly, Team 12-5, Lancaster Spring 2015 Lid van Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 12
Altijd: 129
