Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lay the device on its back and unpeel the silicone base.
Unscrew the four 5mm Torx Security #10 at base.
Return the device rightside up and unpeel the black display cover over the sensor board.
Unscrew the two 3mm Torx Security #6 screws on the edge of the device.
Unscrew the two 5mm Torx Security #10 in the middle of the device.
Unscrew the two 4mm Torx Security #10 screws on the top edge.
Unscrew the six 10mm Torx Security #10 screws around the perimeter.
Remove the four 10mm Torx Security #10 screws around each individual speakers.
Loosen the two Torx Security #10 screws under the speaker using pliers or a long screwdriver.
Één andere persoon heeft deze handleiding voltooid.
