Ga door naar hoofdinhoud
Monster DNA Speaker Replacement
Wat je nodig hebt
  1. Monster DNA Speaker Replacement, Speaker: stap 1, afbeelding 1 van 2 Monster DNA Speaker Replacement, Speaker: stap 1, afbeelding 2 van 2
    • Remove the ear cushions and use a Phillips #2 screwdriver to unscrew the three 5mm screws.
    • Desolder the wires to completely remove the speaker.
    • Take note of the proper location of the wires reassembly.
    • Use a heatgun to loosen the glue holding down the speaker.
    • Be careful to take safety precautions such as gloves as not to cause injury.
  2. Monster DNA Speaker Replacement: stap 4, afbeelding 1 van 1
    • Pry the speaker out using a plastic opening tool or metal spudger.
    • Using too much force will damage the headphones and the new speaker may not go back into place properly.
  3. Monster DNA Speaker Replacement: stap 5, afbeelding 1 van 1
    • Insert new speaker and solder the five wires into corresponding positions onto the new speaker.
Conclusie
Kevin Costello
231 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S4-G5, Julie Spring 2017 Lid van UMass Dartmouth, Team S4-G5, Julie Spring 2017
UMASSD-JULIE-S17S4G5
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,582
