Ga door naar hoofdinhoud
Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement
Wat je nodig hebt
  1. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement, Replacing a Rotating Brush: stap 1, afbeelding 1 van 1
    • Turn vacuum off before starting the fix.
    • Power-off vacuum by pressing the button on the left-rear side of vacuum until the red light is off.
    • Lay vacuum down with handle lying flat on the floor.
  2. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: stap 2, afbeelding 1 van 2 Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: stap 2, afbeelding 2 van 2
    • Remove and empty dust tray; make sure to clean any debris built up.
    • Lay vacuum up-side-down, locating the broken brush.
  3. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: stap 3, afbeelding 1 van 1
    • Turn the lock counter-clockwise to unlock access to the rotation brush; use a key or flathead screwdriver to fit the lock.
    • Remove the square brush cover to access the rotation brush.
    • Once unlocked, the small square brush holder will detach.
  4. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: stap 4, afbeelding 1 van 1
    • Remove the large band from the rotation brush.
    • Push the band to the side and lift up the right-side of the brush.
  5. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: stap 5, afbeelding 1 van 1
    • Detach left-side of the brush from the vacuum.
  6. Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: stap 6, afbeelding 1 van 2 Model-V2945Z Cordless Shark Floor and Carpet Sweeper-Rotating Brush Replacement: stap 6, afbeelding 2 van 2
    • Use scissors to cut away any debris entangled in the brush.
    • The brush is easily damaged by debris if not cleaned regularly; keeping the brush clean lengthens the life of the vacuum.
    • Clean the area surrounding the brush by scraping with a putty knife before inserting the replacement brush.
Conclusie
To reassemble the device, follow these instructions in reverse order.
Robert Whelan
31 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 74
Altijd: 3,063
