Ga door naar hoofdinhoud
Modal Rechargeable Wine Opener Power Button Replacement
Wat je nodig hebt
  1. Modal Rechargeable Wine Opener Power Button Replacement, Modal Rechargeable Wine Opener power button: stap 1, afbeelding 1 van 1
    • Carefully place the spudger under the black cylindrical ring and pry it off the top.
  2. Modal Rechargeable Wine Opener Power Button Replacement: stap 2, afbeelding 1 van 1
    • Remove the spring
    • Remove the spring guide as well to obtain clear access to the screws
  3. Modal Rechargeable Wine Opener Power Button Replacement: stap 3, afbeelding 1 van 3 Modal Rechargeable Wine Opener Power Button Replacement: stap 3, afbeelding 2 van 3 Modal Rechargeable Wine Opener Power Button Replacement: stap 3, afbeelding 3 van 3
    • Remove all four 4mm screws with a J1 Screwdriver
    • Remove the clear cylindrical cap
  4. Modal Rechargeable Wine Opener Power Button Replacement: stap 4, afbeelding 1 van 3 Modal Rechargeable Wine Opener Power Button Replacement: stap 4, afbeelding 2 van 3 Modal Rechargeable Wine Opener Power Button Replacement: stap 4, afbeelding 3 van 3
    • Apply pressure to both of the springs on the surface near the corkscrew, releasing the button port.
  5. Modal Rechargeable Wine Opener Power Button Replacement: stap 5, afbeelding 1 van 3 Modal Rechargeable Wine Opener Power Button Replacement: stap 5, afbeelding 2 van 3 Modal Rechargeable Wine Opener Power Button Replacement: stap 5, afbeelding 3 van 3
    • Remove the malfunctioning buttons from the plastic frame.
Conclusie
Lauren Spicher
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team 15-4, Remmell Spring 2017 Lid van USF Tampa, Team 15-4, Remmell Spring 2017
USFT-REMMELL-S17S15G4
4 Leden
1 handleiding geschreven
3 opmerkingen
where do you by the replacement switch?
Stan Okumura - Antwoord
are there any posts for fixing the usb charging port?
Cristian Sanabria - Antwoord
If the lights work, the buttons are not the problem. I can get the cork screw to turn manually, but it will not continue run beyond a few tries. Must be the motor.
tom.o@mac.com - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 149
Altijd: 7,286
