Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Loosen the plastic knob holding the saw's cutting head in place.
Lower the cutting head while keeping it steady.
Loosen the plastic knob holding the blade cover in place.
Loosen the wing nut on the blade cover pivot shaft.
Remove the wing nut and accompanying washer.
Pivot the blade cover up and pull it off the shaft.
Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
