Ga door naar hoofdinhoud
Mitsubishi VLT-HC3800LP Bulb Replacement
Wat je nodig hebt
  1. Mitsubishi VLT-HC3800LP Bulb Replacement, Bulb: stap 1, afbeelding 1 van 1
    • Remove both screws as shown and gently pull the metallic frame. It is anchored on two small notches on the other side.
  2. Mitsubishi VLT-HC3800LP Bulb Replacement: stap 2, afbeelding 1 van 3 Mitsubishi VLT-HC3800LP Bulb Replacement: stap 2, afbeelding 2 van 3 Mitsubishi VLT-HC3800LP Bulb Replacement: stap 2, afbeelding 3 van 3
    • Remove both screws onn the handle side, and both dark screws on the opposite side.
    • Slightly pull the metal frame (1) and lift the housing top half (2) to reveal the bulb.
  3. Mitsubishi VLT-HC3800LP Bulb Replacement: stap 3, afbeelding 1 van 3 Mitsubishi VLT-HC3800LP Bulb Replacement: stap 3, afbeelding 2 van 3 Mitsubishi VLT-HC3800LP Bulb Replacement: stap 3, afbeelding 3 van 3
    • Remove the black stickers hiding both screws that will have to be removed in this step.
  4. Mitsubishi VLT-HC3800LP Bulb Replacement: stap 4, afbeelding 1 van 1
    • Lift the bulb and its holder from the housing frame.
    • It will then be easier to disconnect the cables
  5. Mitsubishi VLT-HC3800LP Bulb Replacement: stap 5, afbeelding 1 van 3 Mitsubishi VLT-HC3800LP Bulb Replacement: stap 5, afbeelding 2 van 3 Mitsubishi VLT-HC3800LP Bulb Replacement: stap 5, afbeelding 3 van 3
    • Remove the 4 screws and gently lift the frame maintaining the bulb.
    • Note the two notches which will only allow one way to mount the frame.
    • Note the bulb's contacts orientation.
    • Handle the replacement bulb with extreme care. Avoid touching it with bare hands. Bulbs don't like fingerprints at all!
  6. Mitsubishi VLT-HC3800LP Bulb Replacement: stap 6, afbeelding 1 van 1
    • Done!
    • Put the lamp back in place according to your projector's user manual.
Conclusie
ralf
333 Reputatie
2 handleidingen geschreven
Één opmerking
Did my Mitsubishi HC4000 today with lamp only..Found this after the event but useful anyway!
swingmanic - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 8,686
