Inleiding
This quick guide will help you disassemble a Mitsubishi T200 phone, install a new screen, and reassemble your device.
  1. Begin disassembling the phone by removing the phone back cover and battery. Begin disassembling the phone by removing the phone back cover and battery.
    • Begin disassembling the phone by removing the phone back cover and battery.
  2. To remove the back plate, loosen and remove the four screws by using a #00 Philips head screwdriver.
    • To remove the back plate, loosen and remove the four screws by using a #00 Philips head screwdriver.
  3. Separate the front plastic component from the motherboard component.
    • Separate the front plastic component from the motherboard component.
  4. Take the circuit board off the motherboard.
    • Take the circuit board off the motherboard.
  5. MacBook-reparatiesets voor batterijen
    Vanaf $69.99
    Buy Now
    Vanaf $69.99
    Buy Now
  6. Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board. Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board.
    • Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board.
  7. Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board. Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board.
    • Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board.
  8. We can now insert the new screen and reassemble the device. Place the ribbon of the new screen into the clip on the top right of the circuit board.
    • We can now insert the new screen and reassemble the device.
    • Place the ribbon of the new screen into the clip on the top right of the circuit board.
  9. Clip the new screen onto the circuit board.
    • Clip the new screen onto the circuit board.
  10. Replace circut board back on top of motherboard.
    • Replace circut board back on top of motherboard.
  11. Take the entire internal assembly and join it with the front plastic housing.
    • Take the entire internal assembly and join it with the front plastic housing.
    • Ensure that the tops of both pieces clip into place before joining the bottom ones.
  12. Join the phone's face assembly to the back plastic housing. Make sure you carefully insert the front into the antenna's clip first.
    • Join the phone's face assembly to the back plastic housing. Make sure you carefully insert the front into the antenna's clip first.
    • Snap the whole unit together.
  13. Firmly replace screws into the backing.
    • Firmly replace screws into the backing.
Eindstreep
Taylor Lewis
14 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-5, Meza Spring 2014 Lid van Ohio State, Team 1-5, Meza Spring 2014
OSU-MEZA-S14S1G5
4 Leden
4 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 595
