Inleiding
This guide provides step-by-step instructions to update the firmware of your Mitsubishi Hands Free Module (HFM). By keeping your HFM's firmware up to date, you ensure optimal performance, compatibility with new devices, and access to the latest features.
Note that once the update is completed, the system will be reset and the following information will be deleted:
- Phone book data
- Pairing data
- Voice Recognition data
Wat je nodig hebt
Turn the Ignition switch to the ACC or ON position.
Switch off the radio and CD player by pressing on the PWR/VOL knob.
Press the following buttons in that order within sixty seconds from Step 1:
The 1 RPT button.
The ⏮ button.
The ⏭ button.
The 4 ⏩ button.
The display should now read
HFM DIAG
Press the 4 ⏩ button twice to display the Software Version.
Check if the Firmware Version works with your device.
Download the Firmware for your device.
Press on SHOW ALL.
Download update.package.
Copy the update.package file to the root directory of the USB flash drive.
Insert the USB flash drive into one of the USB ports in your car.
Re-enter the HFM DIAG-Section of the Diagonstic Menu by repeating the previous steps or pressing the 3 ⏪ button four times while displaying the Version Number.
Initiate the Update by pressing the PAGE button.
When the display reads
CODE_
, enter the Security PIN using the number buttons. -
Perform the following steps to remove your Security PIN, if you have forgotten it:
Return to
HFM DIAG
by pressing the PAGE button. -
Forecefully remove the Security PIN by pressing the the DISP button. The display should now read
UNLOCK
The display will return to
HFM DIAG
after 3 seconds. You can now proceed by repeating Step 9.
The update will start 3 seconds after you entered the correct Security PIN.
Wait for the update to finish.
Once the update is completed the display will read
UPDATE COMPLETE
Drive safe!
Drive safe!
