Ga door naar hoofdinhoud
Mitsubishi Diamondpoint NXM76LCD Speaker Replacement
Wat je nodig hebt
  1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: stap 1, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: stap 1, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: stap 1, afbeelding 3 van 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the 5 screws: stap 2, afbeelding 1 van 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: stap 3, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: stap 3, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: stap 3, afbeelding 3 van 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: stap 4, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: stap 4, afbeelding 2 van 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: stap 5, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: stap 6, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: stap 6, afbeelding 2 van 2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: stap 7, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the Phillips #2 screws from the speaker(s).
  8. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: stap 8, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: stap 8, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: stap 8, afbeelding 3 van 3
    • Pull the speaker off the slots.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Padraic Hoselton
4.180 Reputatie
12 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.536 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 84
