Ga door naar hoofdinhoud
Mitsubishi Diamondpoint NXM76LCD Display Replacement
Wat je nodig hebt
  1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: stap 1, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: stap 1, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: stap 1, afbeelding 3 van 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: stap 2, afbeelding 1 van 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: stap 3, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: stap 3, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: stap 3, afbeelding 3 van 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: stap 4, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: stap 4, afbeelding 2 van 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: stap 5, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: stap 5, afbeelding 2 van 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: stap 6, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: stap 6, afbeelding 2 van 2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: stap 7, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: stap 7, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: stap 7, afbeelding 3 van 3
    • Pull the two tabs.
    • Pull the connector off.
  8. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: stap 8, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: stap 8, afbeelding 2 van 2
    • Remove the switch cable off.
    • Remove the two Phillips #2 screws.
  9. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: stap 9, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: stap 9, afbeelding 2 van 2
    • Remove the four display power cables.
    • These cables are interchangeable.
  10. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: stap 10, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: stap 10, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: stap 10, afbeelding 3 van 3
    • Lift the display out.
  11. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: stap 11, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: stap 11, afbeelding 2 van 2
    • Remove the four Phillips #2 screws.
    • These screws release the display from its enclosure. Hold the screen when removing these screws.
  12. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: stap 12, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: stap 12, afbeelding 2 van 2
    • Remember to plug in all the cables on the display.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Padraic Hoselton
4.180 Reputatie
12 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.539 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 156
