Ga door naar hoofdinhoud
Mitsubishi Diamondpoint NXM76LCD Display Replacement
Wat je nodig hebt
  1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: stap 1, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: stap 1, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: stap 1, afbeelding 3 van 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: stap 2, afbeelding 1 van 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: stap 3, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: stap 3, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: stap 3, afbeelding 3 van 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: stap 4, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: stap 4, afbeelding 2 van 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: stap 5, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: stap 5, afbeelding 2 van 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: stap 6, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: stap 6, afbeelding 2 van 2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: stap 7, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: stap 7, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: stap 7, afbeelding 3 van 3
    • Pull the two tabs.
    • Pull the connector off.
  8. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: stap 8, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: stap 8, afbeelding 2 van 2
    • Remove the switch cable off.
    • Remove the two Phillips #2 screws.
  9. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: stap 9, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: stap 9, afbeelding 2 van 2
    • Remove the four display power cables.
    • These cables are interchangeable.
  10. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: stap 10, afbeelding 1 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: stap 10, afbeelding 2 van 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: stap 10, afbeelding 3 van 3
    • Lift the display out.
  11. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: stap 11, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: stap 11, afbeelding 2 van 2
    • Remove the four Phillips #2 screws.
    • These screws release the display from its enclosure. Hold the screen when removing these screws.
  12. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: stap 12, afbeelding 1 van 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: stap 12, afbeelding 2 van 2
    • Remember to plug in all the cables on the display.
Conclusie
Padraic Hoselton
4.366 Reputatie
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 33
Altijd: 378
