Ga door naar hoofdinhoud
Minolta QTsi Maxxum Lens Replacement
Wat je nodig hebt
  1. Minolta QTsi Maxxum Lens Replacement, Lens: stap 1, afbeelding 1 van 2 Minolta QTsi Maxxum Lens Replacement, Lens: stap 1, afbeelding 2 van 2
    • The lens release button is located on the right front side of the camera.
    • Remove the lens from the camera by pushing the lens release button.
  2. Minolta QTsi Maxxum Lens Replacement: stap 2, afbeelding 1 van 1
    • The detached module has multiple screws that must be removed in order to reach the lens.
    • Once detached, remove the (4) black Phillips #00 5mm screws from the outer rim of the module.
    • Next, remove the (2) remaining black Phillips #00 5mm screws.
  3. Minolta QTsi Maxxum Lens Replacement: stap 3, afbeelding 1 van 2 Minolta QTsi Maxxum Lens Replacement: stap 3, afbeelding 2 van 2
    • Once all screws have been removed, take the back piece off of the lens and replace it.
    • This piece should come off easily without using any tools.
    • There is film underneath the last 2 screws that are removed so be careful when taking it out because it could rip.
Conclusie
Jordan Ellery
388 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 586
