Ga door naar hoofdinhoud
Minolta QTsi Maxxum Eyelet Straps Replacement
Wat je nodig hebt
  1. Minolta QTsi Maxxum Eyelet Straps Replacement, Eyelet Straps: stap 1, afbeelding 1 van 1
    • The battery compartment is located on the bottom panel of the camera.
    • Use a coin to open the battery compartment of the camera.
    • Twist the coin counterclockwise in order to release the latch.
  2. Minolta QTsi Maxxum Eyelet Straps Replacement: stap 2, afbeelding 1 van 1
    • Once the compartment is open, grab the batteries and pull them out of the compartment.
    • There should be two batteries inside the battery compartment.
  3. Minolta QTsi Maxxum Eyelet Straps Replacement: stap 3, afbeelding 1 van 1
    • With a screwdriver, remove the (7) black Phillips #00 5mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
    • Once all the screws are removed, the panel should easily come off.
  4. Minolta QTsi Maxxum Eyelet Straps Replacement: stap 4, afbeelding 1 van 1
    • Once the bottom panel is removed, the one screw at the bottom of the battery compartment should be visible.
    • Remove the (1) black Phillips #00 5mm screw from the battery compartment.
  5. Minolta QTsi Maxxum Eyelet Straps Replacement: stap 5, afbeelding 1 van 1
    • Press the release button on the side panel to pop open the back piece of the camera.
  6. Minolta QTsi Maxxum Eyelet Straps Replacement: stap 6, afbeelding 1 van 1
    • Once the back panel is open, the chamber containing one screw should be visible.
    • Remove the (1) black Phillips #00 5mm screw inside.
  7. Minolta QTsi Maxxum Eyelet Straps Replacement: stap 7, afbeelding 1 van 2 Minolta QTsi Maxxum Eyelet Straps Replacement: stap 7, afbeelding 2 van 2
    • Take out the (2) Phillips #00 5mm screws on the right side panel of the camera.
    • Remove the (1) Phillips #00 5mm screw on the left side panel of the camera.
    • Remove the side panels from the camera and set them aside .
    • Be careful when removing side panels. There is a plastic piece and spring underneath the left side panel that could get lost.
  8. Minolta QTsi Maxxum Eyelet Straps Replacement: stap 8, afbeelding 1 van 1
    • When looking at the back of the camera, there should be a single screw on each side of the viewfinder.
    • Remove these (2) silver Phillips #00 5mm screws from each side of the viewfinder.
  9. Minolta QTsi Maxxum Eyelet Straps Replacement: stap 9, afbeelding 1 van 1
    • When looking at the top of the camera, the flash hood is visible.
    • Lift the flash hood and remove the (1) silver Phillips #00 5mm screw.
  10. Minolta QTsi Maxxum Eyelet Straps Replacement: stap 10, afbeelding 1 van 2 Minolta QTsi Maxxum Eyelet Straps Replacement: stap 10, afbeelding 2 van 2
    • The top panel of the camera should now be easy to pop off. If it is not, make sure that all screws listed in steps 3-9 are removed.
    • Lift the top panel away from the rest of the camera.
    • Be careful when removing the top panel because there are wires connected to it.
  11. Minolta QTsi Maxxum Eyelet Straps Replacement: stap 11, afbeelding 1 van 1
    • Once all parts of the camera are removed, both eyelet straps should be visible on the top left and right sides.
    • Unscrew the (4) black Phillips #00 5mm screws to remove each eyelet strap holder and replace them.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Maya Van Londen
315 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 345
