Inleiding
Have you broken or damaged the rings your camera strap attaches to? Here's how to replace them.
Wat je nodig hebt
Use the edge of a coin to twist open the battery compartment on the bottom of the camera. (Twist counterclockwise)
Remove the black Phillips #00 5mm screw at the bottom of the battery chamber.
Starting beneath the "SPOT" button, use the round side of the metal spudger and firmly pry underneath the grey top panel of the camera. Work your way counterclockwise around the camera prying at different spots until the top panel starts to come loose. Pry all the way around until you reach the "STsi" logo.
Remove the four black 5.0 mm Phillips #00 screws to remove the strap holders.
