Ga door naar hoofdinhoud
Minolta Maxxum QTSI Tripod Mount Replacement
Wat je nodig hebt
  1. Minolta Maxxum QTSI Tripod Mount Replacement, Tripod Mount: stap 1, afbeelding 1 van 1
    • With a screwdriver, remove the (7) black Phillips #00 5.0mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
  2. Minolta Maxxum QTSI Tripod Mount Replacement: stap 2, afbeelding 1 van 2 Minolta Maxxum QTSI Tripod Mount Replacement: stap 2, afbeelding 2 van 2
    • Once all the screws are removed, the panel should easily come off.
    • Remove the bottom panel of the camera by placing your index finger and thumb on the outer edges of the panel.
    • Pull the bottom panel towards you, it should come off easily.
  3. Minolta Maxxum QTSI Tripod Mount Replacement: stap 3, afbeelding 1 van 1
    • The tripod socket is visible when the bottom panel is removed.
    • Remove the (3) black Phillips #00 6.25mm screws from the tripod socket.
    • When the screws are removed, the tripod socket is free and can easily be lost.
  4. Minolta Maxxum QTSI Tripod Mount Replacement: stap 4, afbeelding 1 van 2 Minolta Maxxum QTSI Tripod Mount Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers to gently remove the tripod socket, and replace it.
Conclusie
Jordan Ellery
388 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 361
