Ga door naar hoofdinhoud
Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement
Wat je nodig hebt
  1. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement, Gearcase Insulator: stap 1, afbeelding 1 van 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement, Gearcase Insulator: stap 1, afbeelding 2 van 2
    • Pull up on the shoe release lever until it's perpendicular to the gearcase insulator.
  2. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement: stap 2, afbeelding 1 van 1
    • Pull the shoe assembly out from the saw.
  3. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement: stap 3, afbeelding 1 van 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement: stap 3, afbeelding 2 van 2
    • Remove the gearcase insulator by folding over the rubber, dislodging the insulator from the red shift lever, and pulling it off.
    • Using the screwdriver to help lift the rubber over the lever and folding it over may be helpful.
  4. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement, Shoe Retainer: stap 4, afbeelding 1 van 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement, Shoe Retainer: stap 4, afbeelding 2 van 2
    • Use a Torx T20 screwdriver to remove the two 4.2 mm screws that secure the shoe retainer.
    • The second screw is on the opposite side.
  5. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement: stap 5, afbeelding 1 van 1
    • The shoe pin attaches the retainer to the gearcase and will need to be removed to fully remove the retainer.
    • Use a flathead screwdriver to push the shoe pin from one side of the gearcase to the other.
    • Twist the pin with your finger to remove the pin from the saw.
  6. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Shoe Retainer Replacement: stap 6, afbeelding 1 van 1
    • Remove the shoe retainer.
Conclusie
Yasminekl1716
97 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 35
