Ga door naar hoofdinhoud
Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement
Wat je nodig hebt
  1. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement, Gearcase Insulator: stap 1, afbeelding 1 van 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement, Gearcase Insulator: stap 1, afbeelding 2 van 2
    • Pull up on the shoe release lever until it's perpendicular to the gearcase insulator.
  2. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement: stap 2, afbeelding 1 van 1
    • Pull the shoe assembly out from the saw.
  3. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement: stap 3, afbeelding 1 van 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement: stap 3, afbeelding 2 van 2
    • Remove the gearcase insulator by folding over the rubber, dislodging the insulator from the red shift lever, and pulling it off.
    • Using the screwdriver to help lift the rubber over the lever and folding it over may be helpful.
  4. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement, Service Armature: stap 4, afbeelding 1 van 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement, Service Armature: stap 4, afbeelding 2 van 2
    • Use a Torx TR20 screwdriver to remove unscrew the four 57.2 mm screws that secure the service field.
  5. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement: stap 5, afbeelding 1 van 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Service Armature Replacement: stap 5, afbeelding 2 van 2
    • While holding the motor housing, pull out the service armature.
    • Putting your replacement service armature in can be tricky, but remember the spring at the bottom needs to be loaded.
Conclusie
Diego
85 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 43
