Ga door naar hoofdinhoud
Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement
Wat je nodig hebt
  1. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement, Power Cord: stap 1, afbeelding 2 van 2
    • Use a TR20 Torx screwdriver to remove the five 15.9 mm screws that secure the two halves of the handle together.
    • Use a TR20 Torx screwdriver to remove the two 25.4 mm screws near the motor housing.
  2. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: stap 2, afbeelding 1 van 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: stap 2, afbeelding 2 van 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: stap 2, afbeelding 3 van 3
    • Use a TR20 Torx screwdriver to remove the single 15.9 mm screw that secures the trigger mechanism.
    • Gently lift the trigger mechanism from the handle casing and unseat the power cord wires from their slotted position.
  3. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: stap 3, afbeelding 1 van 1
    • Use light pressure to pull the white and black wires from the trigger mechanism.
  4. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: stap 4, afbeelding 1 van 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: stap 4, afbeelding 2 van 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: stap 4, afbeelding 3 van 3
    • Notice the small windows on the side of the trigger mechanism; this is where the wires attach.
    • Apply pressure to open these windows with a small flathead screwdriver; this is to ensure the wires are securely in place.
    • Insert the white and black wires from the replacement cord in the sockets perpendicular to the windows.
Conclusie
Jaydon0125
355 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 59
