Ga door naar hoofdinhoud
Milwaukee M12 2407-20 Speed Selector Lever Replacement
Wat je nodig hebt
  1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Speed Selector Lever Replacement: stap 2, afbeelding 1 van 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: stap 3, afbeelding 1 van 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: stap 3, afbeelding 2 van 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: stap 3, afbeelding 3 van 3
    • Remove the unit from the housing assembly and set the housing assembly aside.
  4. Milwaukee M12 2407-20 Speed Selector Lever Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger to pry the broken speed selector lever off the assembly.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,608
