Ga door naar hoofdinhoud
Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement
Wat je nodig hebt
  1. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: stap 1, afbeelding 1 van 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: stap 1, afbeelding 2 van 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: stap 1, afbeelding 3 van 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device, making the gray part face to the right.
    • Remove four 14mm screws using a T20 Torx screwdriver.
    • Remove four 18mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: stap 2, afbeelding 1 van 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: stap 2, afbeelding 2 van 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: stap 2, afbeelding 3 van 3
    • Hold the device so the gearbox assembly faces directly towards you.
    • Remove the four screws using a T20 Torx screwdriver.
    • Using a plastic opening tool, pry the gearbox assembly away from the clam shell.
  3. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: stap 3, afbeelding 1 van 1
    • After all necessary screws are removed, gently remove the upper red cover from the device.
    • Remove the gray motor and gearbox assembly.
    • Remove the gearbox gently as to not damage the brushes.
  4. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: stap 4, afbeelding 1 van 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: stap 4, afbeelding 2 van 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: stap 4, afbeelding 3 van 3
    • Attach a bearing removal tool to the bearing.
    • Tighten the bearing puller until the bearing comes off of the motor shaft.
    • For easier removal, lightly heat the bearing with a propane torch.
    • Heat and then press the replacement bearing onto the shaft.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 590
