Inleiding
The forward/reverse switch is one of the most sensitive part of this device. Owners of this device have mentioned that the switch is prone to fail due to overuse. Though replacement is not very hard, be cautious of the wires around it.
If the forward/reverse switch is not working or fails to function, use this guide to replace it in your device.
Wat je nodig hebt
Flip the device and remove four 18mm screws using screws using a T20 Torx screwdriver.
Remove four 14mm screws using a T20 Torx screwdriver.
