Ga door naar hoofdinhoud
Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement
Wat je nodig hebt
  1. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement: stap 2, afbeelding 1 van 1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Directional Switch: stap 3, afbeelding 1 van 3 Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Directional Switch: stap 3, afbeelding 2 van 3 Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Directional Switch: stap 3, afbeelding 3 van 3
    • Remove the trigger assembly completely.
    • Remove the directional switch by lifting upward using a pair of tweezers, clearing the alignment pole on the trigger assembly.
    • Insert a new directional switch by aligning the hole on the switch with the pole on the trigger.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 911
