Ga door naar hoofdinhoud
Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement
Wat je nodig hebt
  1. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Outer Casing: stap 1, afbeelding 1 van 1
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement: stap 2, afbeelding 1 van 1
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: stap 3, afbeelding 1 van 3 Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: stap 3, afbeelding 2 van 3 Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: stap 3, afbeelding 3 van 3
    • Pulling directly outward, remove the driver head from the motor assembly by picking it up out of the casing.
  4. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement: stap 4, afbeelding 1 van 1
    • Remove the drive shaft assembly from the motor coils.
    • There will be resistance when removing the drive shaft as there is magnetism working against you.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 738
