Ga door naar hoofdinhoud
Inleiding
The following repair guide shows how to remove and replace the Milwaukee Hex Impact Driver 2750-20 driver head in an easy and effective manner.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the five T9 15.5 mm screws.
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Remove the drill casing to expose the drill's interior parts.
    • Remove the drill casing to expose the drill's interior parts.
  3. Lift the driver head and motor assembly directly out of the outer casing. Pull the driver head away from the motor assembly, separating the two. Pull the driver head away from the motor assembly, separating the two.
    • Lift the driver head and motor assembly directly out of the outer casing.
    • Pull the driver head away from the motor assembly, separating the two.
Conclusie
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 4
Altijd: 81
