Ga door naar hoofdinhoud
Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement
Wat je nodig hebt
  1. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: stap 1, afbeelding 1 van 2 Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: stap 1, afbeelding 2 van 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: stap 2, afbeelding 1 van 2 Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: stap 2, afbeelding 2 van 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Forward/Reverse Switch: stap 3, afbeelding 1 van 1
    • Gently move the trigger assembly out of the way and remove the switch from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 30
Altijd: 1,709
