Ga door naar hoofdinhoud
Milwaukee 5262-21 Motor Housing Replacement
Wat je nodig hebt
  1. Milwaukee 5262-21 Motor Housing Replacement, Housing Assembly: stap 1, afbeelding 1 van 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Motor Housing Replacement: stap 2, afbeelding 1 van 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: stap 3, afbeelding 1 van 2 Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: stap 3, afbeelding 2 van 2
    • Now the two 10mm T-10 screws shown in red can be removed.
    • Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
  4. Milwaukee 5262-21 Motor Housing Replacement: stap 4, afbeelding 1 van 2 Milwaukee 5262-21 Motor Housing Replacement: stap 4, afbeelding 2 van 2
    • Using the metal spudger, remove each brush holder as shown in the images.
  5. Milwaukee 5262-21 Motor Housing Replacement: stap 5, afbeelding 1 van 3 Milwaukee 5262-21 Motor Housing Replacement: stap 5, afbeelding 2 van 3 Milwaukee 5262-21 Motor Housing Replacement: stap 5, afbeelding 3 van 3
    • Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
  6. Milwaukee 5262-21 Motor Housing Replacement: stap 6, afbeelding 1 van 2 Milwaukee 5262-21 Motor Housing Replacement: stap 6, afbeelding 2 van 2
    • After removing the four screws, pull apart the the two sections.
  7. Milwaukee 5262-21 Motor Housing Replacement: stap 7, afbeelding 1 van 2 Milwaukee 5262-21 Motor Housing Replacement: stap 7, afbeelding 2 van 2
    • Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
    • These screws hold the fan baffle in place.
  8. Milwaukee 5262-21 Motor Housing Replacement: stap 8, afbeelding 1 van 2 Milwaukee 5262-21 Motor Housing Replacement: stap 8, afbeelding 2 van 2
    • Remove the fan baffle by pulling it out.
  9. Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: stap 9, afbeelding 1 van 2 Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: stap 9, afbeelding 2 van 2
    • Pull the black wire(shown in the image) out of the trigger assembly.
  10. Milwaukee 5262-21 Motor Housing Replacement: stap 10, afbeelding 1 van 2 Milwaukee 5262-21 Motor Housing Replacement: stap 10, afbeelding 2 van 2
    • Pull the white wire (shown in the image) out of the trigger assembly.
  11. Milwaukee 5262-21 Motor Housing Replacement: stap 11, afbeelding 1 van 2 Milwaukee 5262-21 Motor Housing Replacement: stap 11, afbeelding 2 van 2
    • Using a metal spudger slide the black wire (shown in the image) out of the trigger assembly.
  12. Milwaukee 5262-21 Motor Housing Replacement: stap 12, afbeelding 1 van 2 Milwaukee 5262-21 Motor Housing Replacement: stap 12, afbeelding 2 van 2
    • Using a metal spudger slide the yellow wire (shown in the image) out of the trigger assembly.
  13. Milwaukee 5262-21 Motor Housing Replacement: stap 13, afbeelding 1 van 3 Milwaukee 5262-21 Motor Housing Replacement: stap 13, afbeelding 2 van 3 Milwaukee 5262-21 Motor Housing Replacement: stap 13, afbeelding 3 van 3
    • After disconnecting the wires, push the 120v Field Assembly out of the motor housing.
    • You may need to use a screwdriver to push the assembly from behind.
  14. Milwaukee 5262-21 Motor Housing Replacement: stap 14, afbeelding 1 van 3 Milwaukee 5262-21 Motor Housing Replacement: stap 14, afbeelding 2 van 3 Milwaukee 5262-21 Motor Housing Replacement: stap 14, afbeelding 3 van 3
    • Once the assembly is loose, pull each half out of the housing.
    • Note the orientation of how the halves sit together in the housing before removal.
  15. Milwaukee 5262-21 Motor Housing Replacement: stap 15, afbeelding 1 van 2 Milwaukee 5262-21 Motor Housing Replacement: stap 15, afbeelding 2 van 2
    • Remove the motor housing from the device.
Conclusie
Andrew Floyd
277 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 Lid van UMass Dartmouth, Team S1-G3, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 278
